Uplander 2005-2009
Platform: U-Body
2005 chevrolet uplander passenger power sliding door does not open....
Old September 12th, 2011, 6:17 PM
karabug27's Avatar
Default 2005 chevrolet uplander passenger power sliding door does not open....
I am having a problem with my passenger door not opening or closing with the power option. If I push any of the buttons to open it it just pops it open and doesnt slide. It does nothing if I push it while it's open. I can open and close it manually just fine. What would cause this problem? Thanks in advance.
Old September 14th, 2011, 10:48 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> karabug27,
I recommend taking the vehicle to the dealership for the best diagnosis and repairs of the issue. Let us know how it goes at the dealership.
Breanne
Chevrolet Customer Service
Old September 14th, 2011, 2:08 PM
kevinkpk's Avatar
I recommend you A) Check the fuse to the motor as it's apparent the motor is not working.
B) check the motor switch
C) check motor if the other two are good. I'd suspect switch needs adjusted.
Old September 16th, 2011, 6:20 AM
karabug27's Avatar
Could you tell me where the motor switch is? I believe we already checked the fuse in the fuse box by the passenger door. Thank you for your response
Old September 16th, 2011, 8:10 AM
kevinkpk's Avatar
I don't know where it is, but there has to be one to turn it on, and on to turn it off when the door is open.
Old October 7th, 2011, 9:25 PM
zx6rf7's Avatar
My van has been doing the same thing open just enough to say its open, but then when u push it open it starts the warning signal. Have u found anything out on this??
Old November 16th, 2011, 7:56 PM
zx6rf7's Avatar
I seem to have found the problem with my door check the block of 8 pins that are on the side of the door and see if the bracket is loose mine was I pushed the the plastic bolts back in place and we haven't had any trouble with it since.
reelcharacter
December 6th, 2016 11:11 AM
goyakpacking
Express & G-Series Vans
May 9th, 2015 7:51 PM
LeeHamilton
October 26th, 2014 9:49 PM
chevyLS6
Uplander
May 13th, 2014 4:25 PM
tbejamss
January 25th, 2008 11:43 AM
Quick Reply: 2005 chevrolet uplander passenger power sliding door does not open....
