1990 Chevrolet C 1500 brakes
Old Mar 8, 2018 | 4:02 PM
Daniel Carrie Pirtle's Avatar
Default 1990 Chevrolet C 1500 brakes
My 1990 Chevrolet C 1500 has a soft brake pedal goes to the floor before it stops I replace the master cylinder it's full of fluid replace both front calipers and pads what could be the problem
Old Mar 9, 2018 | 1:26 AM
Did you bleed the master cylinder first then bleed the 4 wheels? Sounds like there is air in the system!
Old Mar 20, 2018 | 6:48 PM
The Crow's Avatar
Hi,
Just an FYI you do need to bench bleed the master cylinder first then install and bleed all 4 wheels starting with the right rear, left rear then right front and left front. Hope this helps.
