1990 K1500 help
Old Jan 30, 2016 | 8:29 PM
Adamfoland's Avatar
Default 1990 K1500 help
Help I have a 90 k1500 was converted to carb before I got it has optional temp amp and oil pressure gauges under dash my problem is my all fuel gauge shows full when empty and speedometer is stuck on 45 I don't know if they took the computer out or not do this cluster operate thru the computer any help or thoughts please tell me
Old Jan 31, 2016 | 9:40 AM
burnhedge's Avatar
Yes the computer needs to be in. No reason to take it out for a carb swap. It's rare for a computer to go bad in the gmt400's but possible.
Old Feb 1, 2016 | 7:24 AM
With the speedometer stuck on 45, I would say it is more likely a problem with the speedometer itself. With no signal or not moving it should go to 0. The fuel gauge may be as simple as a bad sending unit or a bad ground. Always check the simple things before going into more complicated repairs which may not be necessary.
