1991 Chevy Silverado Running Lights
Old Jan 11, 2021 | 10:24 PM
Dan Childers's Avatar
Default 1991 Chevy Silverado Running Lights
Hey all - I got this 1991 Chevy Silverado C 1500 V6 4.3 L for free as rats had an amusement park near it. It runs great 180 k and fixed all electrical issues But Can Not Figure Out Why the Running lights Don't work --rear or front --All Else is good.. R&R'd relay and bulbs work --no voltage to rear lights at harness -Fuse ok. ???? Ideas as I am a savoy person on electrical
Old Jan 31, 2021 | 10:27 PM
Mr. Dude with a face's Avatar
I know it is basic, but check grounds, and try to start at the beginning, somewhere, assuming the truck starts, their is power, you just have to find where it stops, then you have your victim. Sort of a prosses of elimination game. I hope that helps.
Old Feb 11, 2021 | 7:27 PM
HunterSmokes's Avatar
Do both of your turn signals work normally?
I have a 91 C1500 and my signal lever is pretty worn. If I don't lift it to the correct/perfect position, one side of the lights (excluding headlights) shuts off and doesn't work.
So basically I assume there's a possibility that a bad switch can cause both to not work also.
Try the turn signals, make sure the lever rests in a neutral position.
I haven't checked myself but I would assume there is some connection point under the dash to test the switch. If you can find the connection terminals then a continuity test might tell you if that's the issue.
Might not be the issue but is a possibility.
RitualJman
15
Apr 22, 2026 9:15 PM
Dan Childers
1988 - 1998 (GMT400)
Jan 11, 2021 10:03 PM
Marvin666
Apr 26, 2019 6:01 PM
jkaras2000
Aug 27, 2014 5:58 AM
milkmaan
Dec 4, 2010 12:41 PM
