Old Jul 28, 2015, 2:53 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
1994 5.7 starts then stalls
Old Oct 18, 2012 | 1:55 PM
  #11
Subassaultvehicle's Avatar
Same deal on my 94 k1500. Just bought it a week ago. 4k miles on rebuild. Engine tranny transfer case redone. Everything but the little things. Ran like a champ for a week then it started surging untill it stalled out on idle, especially if lights+turnsignals on. Unplugged IAC ran good for a day then back to the issue. Changed that out, it ran about 20 miles fine then, back to the same idle behavior. Noticed the rattle in the catalytic, changed it to magnaflow. Felt better driving, when in idle, same problem. Checked fuel pressure and it found to be low. Changing out fuel pump today. I'll update you after its installed.. In the end hopefully having all the little things updated also will keep this beautifull heap going another 200k miles.
Old Jul 31, 2015 | 4:08 PM
  #12
diver8718's Avatar
What is a iac and what is az
Old Jul 31, 2015 | 4:11 PM
  #13
diver8718's Avatar
what is iac or az?
Old Jul 31, 2015 | 8:31 PM
  #14
burnhedge's Avatar
Default 1994 5.7 starts then stalls
iac= Idle air control valve.
I'm assuming that the guy was referring to autozone as az
Old Aug 2, 2015 | 5:40 PM
  #15
diver8718's Avatar
I have a 95 k1500 I will turn the key on and wait couple seconds and i'll hear a click in the dash and the gauges will come on then it will start fine ? is there a relay or something that would cause that?
Old Jan 4, 2016 | 10:01 PM
  #16
Mike Murray's Avatar
Thanks for all the great ideas but hears what I've done. New modg., coil exstra.. It starts easy then just dyes. What am i missing
Old Aug 10, 2018 | 9:50 PM
  #17
Dakota Prestage's Avatar
I got a 1994 chevrolet 1500 z71 has any of yall ran into the problem it will start run for a little bit but when you give it gas it dies out but if you constantly hit the gas it will run if you keep pushing it (letting off and pushing it again constantly) just put throttle body on module in the destributor ran down a few other things and its still doing the same thing any ideas??
Old Sep 11, 2018 | 5:03 PM
  #18
meternerd's Avatar
English Class!
Old Jun 9, 2022 | 8:20 PM
  #19
chiefcam91's Avatar
Default Did you ever figure out the problem?
did you ever figure out what the issue was?
Old Aug 29, 2024 | 1:02 AM
  #20
obsmama's Avatar
Post
idle air control, auto zone
mdm6713
May 23, 2022 7:41 AM
streetterrorist
13
Apr 15, 2022 1:42 PM
ShadeTreeJack
Aug 2, 2014 12:14 PM
rtbcoop
Jul 16, 2014 7:28 AM
Doug Wells 69
Aug 31, 2013 12:54 PM
