Vortec 5700 no start, no fuel, good spark
Old Jul 13, 2014 | 6:29 PM
rtbcoop's Avatar
Default Vortec 5700 no start, no fuel, good spark
Hi, I've been having some trouble with my 98 Tahoe and wanted to see if I could get some help! The day after I bought it on craigslist, the Tahoe refused to start. It worked fine when I test drove it but the next day it would crank but not start. I found that the roller pin in the bottom of the distributor had sheered off so I replaced the pin, reinstalled the distributor, but it still will not start. I have good fuel pressure when the key is turned and while cranking, good spark, but the plugs are dry after cranking it for a few seconds. I tried starting with gas and carb cleaner down the intake but still nothing. Any help would be greatly appreciated! Thanks!
Old Jul 16, 2014 | 7:28 AM
rtbcoop's Avatar
Update: Fixed the fuel issue. Apparently the injectors will not fire when the battery is too low. After messing with the truck so much, I had to recharge the battery and now my plugs are coming out wet after turning over.
I can get her to start but she runs really rough. I used a timing light just to see where my timing was and it looks like the computer is advancing my timing about 18*. Is this normal?
belair
Jul 18, 2012 2:35 PM
gdavies07
Nov 7, 2011 11:47 PM
dtachia
Apr 23, 2011 1:51 AM
dannymiami
Jan 20, 2011 9:25 PM
devancobb
Feb 5, 2008 10:23 AM
