1995 K1500 With 2004 Column and ls5.3 help?
Old May 18, 2018 | 4:58 PM
livermorek5's Avatar
Default 1995 K1500 With 2004 Column and ls5.3 help?
I picked up this project a few weeks ago but I'm having a hard time finding anyone who has installed the 04 column in a 95 truck. Who ever did the install pretty much stopped at getting the engine running and left the lighting a mess. I could really use a pinout of the large column plug on the 95. I Have some wire diagrams but trying to find all the circuits associated with the column is pain in the ***.
Also any info on the wires coming from the 2004 column.
Old May 20, 2018 | 1:38 PM
Brian D Jones's Avatar
I would go to the 2004 era part of the chevy forum and post there, you probably will have more luck there
Old May 21, 2018 | 11:25 AM
Originally Posted by Brian D Jones
I would go to the 2004 era part of the Chevy forum and post there, you probably will have more luck there
Yeah if my question mostly pertained to 2004 I would of. I was hoping to get the pin-out of a column plug on a 95 Chevy though, not a 2004. A pin out of the plug would still be nice to have, but I solved all my exterior lighting issues by swapping out the 2004 multi-function turn signal switch with a 1995 version. Bolted right onto the 04 column amazingly even the cruise control works with the 04 TAC module.
