1999 Suburban C1500 Possible ECM Failure
Old May 4, 2021 | 9:19 PM
cleyd's Avatar
Default 1999 Suburban C1500 Possible ECM Failure
Hi all,
I decided to throw my scanner on the car and a bunch of codes came up under the OEM Enhanced data. 350 with 206,000k on her.
-P0605
-P0756
-P1870
-P1875 (No clue why a 4WD code would be coming up)
-U1026
-U1024
-U1064
-U1193
I was curious what avenue I should start with in this diag. I was thinking that this could be a possible ground issue. At the moment, there is no drivability issues.
If in the end, the ECM has in fact failed, what does the process look like for reprogramming the new one.... Is a Tech2 needed?
Thanks for the input,
Cole.
Old May 5, 2021 | 9:58 AM
Chris94's Avatar
You could contact a shop that refurbishes vehicle computers and find out what your options are. I tracked down a very frustrating driveability issue on my '97 Corolla that turned out to be a bad ECM. I opened it up and found leaking capacitors. I want to say I paid something like $80+ shipping to have it refurbished.
Old May 5, 2021 | 2:00 PM
Rednucleus's Avatar
So runs well and no check engine light coming on??
Old May 6, 2021 | 7:00 PM
Gumby22's Avatar
Originally Posted by cleyd
Hi all,
-P0605
-P0756
-P1870
-U1026
-U1024
-U1064
-U1193
Cole.
If there’s no driveability concerns or check engine light, it’s most likely these codes are all either pending or in history (not active). Without being erased with a scan tool, some codes can take up to 80 ignition cycles to clear.
The P1875 could be setting because the original PCM was replaced with a PCM out of a 4x4.
If you’re concerned or unsure if any of them need diagnosis, erase them, then check for codes again after a few drives. Any codes that return should be addressed.
Old Jun 16, 2021 | 3:45 AM
The Heater's Avatar
I would go with this suggestion. It is not expensive to have these rebuilt, usually, and that is a lot less misery than trying a buncha other avenues.
LdyMaddog73
1988 - 1998 (GMT400)
May 3, 2021 2:01 PM
Zach Schweinsberg
Apr 22, 2020 1:01 PM
wmm83pack
Apr 25, 2017 8:51 PM
opencircles
Feb 25, 2014 12:14 AM
hook2
Aug 18, 2011 10:01 PM
