Notices
'88 305 head gasket job, now it won't stay running.
Old December 12th, 2017, 3:39 PM
NickAttack's Avatar
Question '88 305 head gasket job, now it won't stay running.
Hi everyone, I just did a head gasket job on my truck. I have a 2 door scottsdale with a 305. After we were all done with it we attempted to start it with no luck. Put it on the battery charger and let it sit for a while. It would then start but only ran while the throttle was cracked open. I have since replaced the distributor and made sure it was in correctly. Then when I went to start it, it would start with the throttle all the way to the floor and once I let off it would die. Anyone have this problem before? I'm at my wits end with it, I just want to drive it again. Should I replace the spark plug wires? Any help or advice is appreciated, thank you all.
Old December 12th, 2017, 3:51 PM
kevinkpk's Avatar
Did you do anything to the carb?
Old December 13th, 2017, 6:27 AM
Was it doing it before the gasket job? Possible vacuum leak.
Old December 13th, 2017, 12:28 PM
NickAttack's Avatar
No. When I was taking everything apart all I did was take it off and set it away. To my knowledge nothing was done to it, but I could be wrong.
Old December 13th, 2017, 12:29 PM
NickAttack's Avatar
No it was running alright (besides needing the head gasket). Only started doing it once it was put back together and started.
Old December 13th, 2017, 3:31 PM
kevinkpk's Avatar
If you didn't do anything to the carb, and everything ran fine other than the head gasket before, only thing in this instance it could be is the intake manifold to head gaskets
Old December 13th, 2017, 11:51 PM
Vacuum leak.
Old December 15th, 2017, 1:05 PM
NickAttack's Avatar
Thank you, I will look into both of those things.
Old December 15th, 2017, 2:52 PM
kevinkpk's Avatar
Did you pull the carb off the intake manifold?
Old January 16th, 2018, 11:52 AM
NickAttack's Avatar
Yes I did. But talking to some coworkers that had trucks almost identical I realized my problem may be I need a new fuel pump and filter since my truck had sat for long enough. They also said that their trucks would bog down when they turned right because the washer that kept the box inside the fuel tank had come off causing it to suck up to the fuel pump then causing it to burn up. So I have both of those on order and should come in this week, and I'll get it changed this weekend. I will let you know what I find out.
