4L60E Problems
Old Jul 29, 2019 | 12:55 PM
WARE 2010's Avatar
Default 4L60E Problems
Driving a 1994 Silverado and the transmission (4L60E) will shift fine until 3rd, then it doesn't want to go in OD or will not downshift after that. Stays in third unless I shut the truck off. Then it'll be the same. Shift to third and stay.
When I disconnect the battery for a few minutes and retry it'll run like it should. Go into OD and downshift but only for a few miles then its back to being stuck in 3rd.
I have not had the opportunity to put in on a computer to see what codes come up. I'm gonna try that today.
Does anyone have any ideas what's going on with this? Any advice would be appreciated.
Old Jul 29, 2019 | 9:35 PM
Sabino56's Avatar
I had a problem once where it wouldn’t go into overdrive except at the beginning of a drive - a 93 5.7l with a 4l60e. In my case it was the membrane switch in the pan. It had a crack in one of the membranes and with pressure would leak in and the contact would fail. After it sat a bit it would evidentially drain out and work for a while.
The selector mech on my 4l60e moves a shift piston which directs pressure to different sections the membrane switch ( not sure what it’s actually called) and the switch tells ECM what position the gear selector is in. I think you should be able to see what gear the ECM believes it is in with a datalogger (at least TunerPro will) and see if that is correct.
If if not that, I don’t have idea or experience with all the ways a auto trans can go wrong! Hopefully someone else has ideas. Good luck!
Old Jul 31, 2019 | 11:29 AM
KChevy75's Avatar
It's called the pressure switch manifold. My trans still wouldn't shift correctly after I performed a full rebuild. I replaced the pressure switch manifold and the problem was resolved.
