4l60e4x4 compatability questions
Old Sep 3, 2022 | 9:10 PM
Nathan Olson's Avatar
Default 4l60e4x4 compatability questions
(Main question)This is my first time on here. I have a 93 chevy cheyenne k1500 with the 4.3 vortec. My transmission seems to be failing and I am looking into replacing it with a used transmission. I was wondering what years of transmissions I can use. I have read that the transmissions changed ever couple years. I am willing to swap out parts from my old transmission to make it work but I don't know what will work year wise, if it has to be from a vehicle that had the 4.3, and if it has to be from a 1500 pickup (as opposed 2500/3500, suburbans, etc).
(the transmission issues)BTW the failures I noticed are (currently) I can feel a grinding/juttering in first gear while accelerating, before I put Lucas oil trans fix it made a grinding noise when shifting but always succesfully shifted, and also before the transmission fix stuff it would make a clunking noise and feeling. The last two did go away with the transmission fix liquid stuff.
(Kinda unrelated issues) i also question is my vss is going bad. Sometimes when coming to a stop at about 1 or 2 mph the antilocks suddenly engage. Then when accelerating my speedometer suddenly jumps to 30 and comes back down to my speed.
Old Sep 4, 2022 | 2:18 AM
oilcanhenry's Avatar
Since you have OBD I, I'd stick with a transmission for that fact alone.
Old Sep 4, 2022 | 9:57 AM
Nathan Olson 2's Avatar
Default I had an issue with my account
this is me. I had an issue with setting up my account and had to make a new one.
Old Nov 10, 2022 | 7:57 PM
peewee2020's Avatar
my 94 chevy z71 4x4 with the 5.7 tbi 350 trans which is a 4l60e it started not wonting to shift to frist i could trun off motor for a couple of min start and it would drive and shift to now once only have frist once trans warm nothing shut motor off then you can drive alittle farther
lwatterly
1988 - 1998 (GMT400)
Mar 21, 2016 11:38 AM
chevykid53
Mar 24, 2013 8:42 PM
Dave8x
Feb 19, 2011 7:34 PM
jharbert
Feb 11, 2008 9:56 PM
