5 lug to 6 lug question
Old May 12, 2018 | 10:38 PM
Waffle_fart's Avatar
Default 5 lug to 6 lug question
My papa has a really clean c1500 that he is going to give to me soon and it’s a beautiful truck that runs great and could be a great base for a build. The only problem is it’s a 5 lug instead of the more common 6 lug. I know I could just use adapters but that isn’t something I want to do. I was thinking of putting a rear end out of a 6 lug truck and that would fix that problem in the rear. But I don’t know what I could do in the front. Could I just get new hubs for the front and that solve the problem? I know if I do this it will be a lot of work for a small outcome but I would much rather be able to run new stocks because I love the look, without the thought in the back of my mind all the time that I’m using adapters. Any help would be amazing. Thanks in advance.
Old May 13, 2018 | 11:44 AM
Brian D Jones's Avatar
I have never messed with axles, hopefully somebody will come along and be able to answer your question. good luck
Old May 13, 2018 | 4:21 PM
The axle isn’t the hard part. A 4wd axle of the same year should bolt right up. It’s the front end I’m confused about
Old Jun 4, 2018 | 12:01 PM
Bump?
