6.2 diesel idle rpm adjust
Old Oct 28, 2020 | 3:24 PM
Finn MaFa's Avatar
Default 6.2 diesel idle rpm adjust
Hi,
How to adjust idle rpm on 6.2 diesel 93 K2500? Or what' s the matter... Now it's too high. Tried to drop it down but when I got it down a bit it started to "die" when stopping for exemple to traffic lights. And it took quite a lot starting to get it running again.
I haven't measured any exact rpm numbers. Otherwise it starts right up even standing for a week.
Old Oct 28, 2020 | 9:02 PM
burnhedge's Avatar
The high idle solenoids (cold advance)can be problematic. Possible that it was engaged when you adjusted the idle speed then disengaged at some point leaving you with too low of an idle
Old Oct 29, 2020 | 1:41 AM
Finn MaFa's Avatar
Hi
and thanks for the tip. I know that first I played with the cold solenoid. There is a adjusting possibility also, was it so? Cause now I think it's not working as it should. Rpm stays the same don't matter if it's cold or warm engine. Any tips how to adjust the cold solenoid properly?
Old Jul 18, 2024 | 6:57 PM
dagixaj337's Avatar
Wallester's White-Label Card Issuing provides a powerful solution for companies looking to offer their customers their own branded payment cards. This service allows businesses to issue payment cards under their own brand without wasting time and resources on developing complex infrastructure and meeting regulatory requirements. You can integrate this feature very quickly thanks to a modern approach to development.
DRo3m
1988 - 1998 (GMT400)
Sep 23, 2022 12:45 PM
aahamed
Feb 24, 2018 10:14 AM
poppee59
13
Mar 3, 2013 5:55 PM
chaser
Apr 11, 2010 5:27 PM
prairieboy9
May 24, 2008 5:28 PM
