94 k1500 manual 5 spd
Old Apr 9, 2022 | 5:48 PM
Mkm@120's Avatar
Default 94 k1500 manual 5 spd
Truck has good clutch , shifts into all gears both trann and transfer case won't move makes a grinding gear noise that is higher pitched in higher gears, thing won't move in any gear or combination of gears between tranny and transfer case, what the he'll is wrong
Old Apr 16, 2022 | 11:37 AM
tank1949's Avatar
Perhaps your clutch master or slave cylinder has become defective. Mine did, right after I replaced clutch pack. With a friend and truck jacked up, examine and make sure slave piston is engaging and compressing pressure plate.
Old Apr 17, 2022 | 8:32 AM
Mkm@120's Avatar
Yea that's not it but thanks for the reply. Someone mentioned rear-end but the front end would still work so I don't know trial and error I guess
Old Apr 17, 2022 | 8:50 AM
hanky's Avatar
Can we ask how it was determined the clutch was good?
If you are getting some result from selecting higher gears and the problem is still there, good chance it is within the transfer case.
Old Apr 18, 2022 | 6:21 AM
tank1949's Avatar
What has changed or have you changed ???????? Any chance you may have disturbed transfer case linkage???? Jack up truck and remove drive shaft and see if differential spins. Pull transfer case and test to see if spins?
Old Apr 18, 2022 | 10:24 AM
Mkm@120's Avatar
Took the clutch out and inspected it, don't know any other way to tell if it was good or not , put a new one in any way since I had it apart. Wouldn't that make sense
Old Apr 18, 2022 | 10:29 AM
Mkm@120's Avatar
Nothing changed transmission and transfer case both turn on the *** end when you spin the front end , I also think it's the transfer case but seems to me it should move in some position
Truss101
Sep 9, 2014 10:40 AM
90guy
Oct 26, 2013 5:21 PM
stepside stewy 96
Jul 25, 2010 4:29 PM
Lemans1955
Mar 5, 2010 10:24 PM
y13supio
Aug 25, 2006 2:57 AM
