94 k1500 starting off of oil pressure
Old Mar 9, 2023 | 9:08 PM
Nerdahl-I's Avatar
Default 94 k1500 starting off of oil pressure
So my 1994 k1500 (4.3l) truck starts after cranking for about ten seconds once it achieves high enough oil pressure I tap the gas then it starts, however after driving at highway speeds for maybe 10-20 minutes it won't start after shutting it off until it cools down. Originally it wouldn't start at all until I bypassed the relay by feeding power from the coil to the other side of the fuel pump fuse with a switch. Brought it to a local Mechanic who fixed some pins to the ecu so I dont need the switch anymore but it still has the same problem of starting off of the oil pressure and not starting again after driving it. I have replaced the relay and the oil pressure switch and neither one did anything, any recommendations on how to fix this?
mikebruce700000
1988 - 1998 (GMT400)
Feb 26, 2017 11:05 AM
Nick Lonsbury
Oct 1, 2015 9:25 PM
91chevy
Sep 5, 2014 6:20 AM
Zackman1995
Feb 19, 2012 8:05 PM
werneb01
May 15, 2006 2:57 PM
