95 Chevy Cheyenne spitting and coughing out of throttle body!!
Old Feb 2, 2020 | 1:33 PM
Austin Stofflet's Avatar
Default 95 Chevy Cheyenne spitting and coughing out of throttle body!!
95 Chevy 1500 350tbi, 5spd.. new map sensor new distributor new ignition module "rebuilt" throttle body, timed with a timing light, new plugs and plug wires, coughs and spits out of throttle body, kind of stumped at this point.. please help...
Old Feb 2, 2020 | 3:09 PM
Irish_alley's Avatar
I'm here for the party
inspect and clean your grounds mainly the battery to engine, engine to firewall and battery to rad support
Old Feb 2, 2020 | 3:16 PM
Thank you.. could timing effect this.. timing was set at 0 degrees.. could two degrees of timing make the difference, I've been reading of guys running 2 degrees
Old Feb 2, 2020 | 4:05 PM
Little Bear's Avatar
plug wires miss wired, timing could do it but it would have to be off a lot.
Old Feb 2, 2020 | 4:06 PM
Rednucleus's Avatar
Please recheck plug wires, make sure they are in correct order. I have oops the wire order before and created the same stack back firing. How was it running before the work was done?
Old Feb 2, 2020 | 4:11 PM
Was running terrible before.. idles alright, but as soon as I push the clutch in and go to pull out it's falls on its face and starts coughing out the throttle body.. it clears out after 2k but as soon as I stop at a stop sign it will stall and spit and pop and carry on before it starts again...
98Silverado1500
Aug 3, 2012 7:25 AM
BigRed922
Jun 30, 2012 4:55 PM
eagleeye13413
Jan 28, 2012 7:04 AM
StormH2Oguy
Jan 6, 2012 7:01 PM
