'96 5.0 engine vibration
Old Dec 15, 2017 | 2:18 PM
xntric1's Avatar
Newly Registered
Default '96 5.0 engine vibration
Recently acquired this truck with a vibration from the motor. I initially assumed it was a balance issue. I replaced the harmonic balancer with a new one, and even with no belts attached still vibrates. Idles fine but as soon as you start to rev the motor, it vibrates exponentially to nearly a teeth-chattering experience. I even pulled the clutch/pressure plate out--no issues there. I'm beginning to now think it's an electrical issue. The only code I've seen is a P0155, but I don't think this would be such a drastic engine vibration issue. Much appreciate any ideas where or what I could possibly look into now!
