96 C1500 Silverado 5.0 Vortex
Old Mar 6, 2023 | 4:06 PM
Donnie71's Avatar
Default 96 C1500 Silverado 5.0 Vortex
New to the group. Have a 96 , replacedEGR valve, map, crank, cold air intake sensor, temperature sensor, distributor, cap rotor,plugs wires,O2 sensors intake and updated injectors.
Truck was running rich, after all installed still running rich smells like bad gas.. Also when warmed up at higher speeds bucks when holding gas steady, the bucking issue was after all was installed. Found out unplugging the EGR stops the bucking.
Still smells rich.
Any help??
Thanks
Old Mar 7, 2023 | 12:00 AM
oilcanhenry's Avatar
Still smells rich.
Any help??
Thanks
Since you have OBD II get us some codes. Also clean your MAF sensor if you have not. Sounds like you need a new EGR Valve.
Old Mar 8, 2023 | 5:48 AM
Donnie71's Avatar
Good morning, has new EGR valve. No codes, found that truck was out of time on the bucking issue. I will clean mass air flow sensor.
Donnie71
1988 - 1998 (GMT400)
Mar 13, 2023 6:40 AM
Donnie71
Mar 6, 2023 5:19 AM
Dr_Kittyhouse
Dec 23, 2021 1:27 AM
aaxelson89
Jul 25, 2014 8:56 AM
gungfu01
Feb 9, 2007 11:30 PM
