96 Silverado 1500 5.7L Alternator Not Charging
Old Feb 3, 2019 | 1:39 PM
Jesus_R's Avatar
Default 96 Silverado 1500 5.7L Alternator Not Charging
My truck has stopped charging. We replaced the alternator(single wire), the battery, and the starter. The truck will still not charge.
Old Feb 3, 2019 | 8:08 PM
First step of any electrical troubleshooting: What is your voltage with the engine running?
If it's less than 13V then your fusible link might have blown.
Old Mar 5, 2019 | 8:40 PM
Terminal Frost's Avatar
Suspect that you don't have 12 volts at the big wire going to the alternator.
Mountain Man is correct, blown fuse in this wire. About a foot from the positive battery terminal is a black bulb on the wire, this is where the fusible link is located
Old Mar 6, 2019 | 8:28 AM
Irish_alley's Avatar
I'm here for the party
also check your voltage at the back of the alternator
