98 2500 low fuel pressure
Old Nov 17, 2017 | 12:43 PM
thomas wood's Avatar
Default 98 2500 low fuel pressure
New to this site
I have a 98 2500 5.7 vortec. It just stopped running, won't start. I replaced fuel pump, relay, and filter. Still won't start, tested fuel pressure and got 38 psi while cranking, and 42 at rest. Any guesseson why the pressure is so low? Thank you
Old Feb 12, 2018 | 8:29 PM
redbear's Avatar
gm throttle body =appx 35psi
vortec? =70?
just guessing here...
JR
Old Feb 12, 2018 | 10:45 PM
oilcanhenry's Avatar
Originally Posted by thomas wood
New to this site
Should be 50 PSI or higher, particularity with a new fuel pump, relay and filter. Might have been sold a defective fuel pump, but very unlikely.
More then likely you have a bad MAP sensor, which if correct, is easier then installing another fuel pump.
