98k1500 No Spark after motor rebuild
Old Apr 22, 2023 | 8:47 AM
98K1500Rob's Avatar
Default 98k1500 No Spark after motor rebuild
Hello I need some help please. I had motor rebuilt. Got it back in and cranks but no spark. Checked no spark at coil. I replaced coil and ignition module, crank position sensor as part of rebuild. I did the variable steering sensor delete as per gm latest so that plug is left unplugged.
I tested the pink wire on cps and read 12 volt. Purple wire did not, .4 volt.
I did notice a security light on when turning key to first position, but it doesn't stay on.
I am stumped on what to test next. Hopefully someone can steer me in right direction.
Thanks
Old Apr 22, 2023 | 1:48 PM
98K1500Rob's Avatar
Thanks
I got it! So pumped. The damn cps wasn't fully seated. It runs awesome!
I still have a cps code p1345. Crank shaft position sensor camshaft position sensor correlation. Probably out of timing. Anyone' know what might cause it
danmoore
Sep 11, 2012 4:17 PM
mfre111
Jun 2, 2012 9:46 PM
JONEDAL
Sep 18, 2011 6:57 PM
wmiller1337
May 22, 2011 10:15 PM
markland556
Dec 7, 2010 2:31 PM
