Blower Motor Quit
Old Dec 21, 2024 | 4:52 PM
dhull's Avatar
Default Blower Motor Quit
My pickup is a basic 1998 with the standard two-dial heater and A/C controls (not climate control). Recently, the blower would stop turning occasionally, but would start back up if I turned the dial off and on again.
I ordered a new blower and installed it, but the new blower doesn't turn at all. I checked the #12 heat/AC fuse and it is intact. I reinstalled the old blower and it doesn't turn at all now either, so I put the new unit back in. Any ideas? Do I need to replace the resistor also?
I have checked the terminals several times and ensured that they both are connected.
Old Dec 21, 2024 | 6:10 PM
Rednucleus's Avatar
Maybe time for a new switch; put 12 v to the old motor and see if it runs to test. Could try spraying the switch innerds with Deoxit
Old Dec 22, 2024 | 8:09 AM
Check to see if voltage gets to the resistor with the switch on high. If it does, I would replace the resistor. You should probably replace it anyway.
Dhornet7
Aug 2, 2023 2:02 PM
ScottyD
Nov 11, 2021 12:15 PM
Bjj1805
Jul 24, 2015 1:54 AM
murphbradyscott
Feb 12, 2012 5:10 AM
mnz24
Dec 18, 2011 7:31 AM
