Climate control, A/C, blend door and mode actuator issue. Help!
Old Jun 5, 2016 | 12:20 PM
gd62390's Avatar
Default Climate control, A/C, blend door and mode actuator issue. Help!
I have a 1995 Chevrolet 2500, automatic, 4x4, 5.7 liter truck. I tried to turn on the A/C and it wouldn't work. I tried to move the air output from the floor to the defrost and it wouldn't change. I watched some videos and talked to some people at the parts store. All signs pointed to the mode actuator on the drivers side. Easy access and only a $40 part. So I bought a new actuator and installed it but it still didn't work. Frustrated, I gave up for the day. Then this morning I went out to start my truck and the A?C and modes worked! I turned off my truck and then turned it back on and the A/C and air modes quit working again. No A/C and air would only come out on the floor. I pulled the A/C fuse, put it back in and it started working again. Not sure if that had anything to do with it because now it works sometimes and sometimes it doesn't. I reinstalled the old actuator and it stills works sometimes for a minute or two and then doesn't. WHAT? Anyone have any ideas what might be going on to make it work and then not? Any help would be appreciated.
Old Oct 16, 2016 | 10:26 PM
L13's Avatar
L13
I had what sounds like a similar issue. Air blows only on dash or floor. Does not blend. No AC. I read online there was an issue with climate control module. The module in cab with ***** and AC button. Common issue on Silverado/ Tahoe for the 95 and a few years before. I replaced the module with an AC Delco one found on Amazon and all is well. Made in Canada too (and not China) I just happened across this fix while researching how to troubleshoot AC.
