Cranks, has spark but no fuel
Old Nov 27, 2017 | 8:36 PM
usmarine0905's Avatar
Default Cranks, has spark but no fuel
Hi, I have a 1998 5.7 Vortec Silverado automatic, it will crank ,has spark but no fuel. Last week I drove to Orlando Florida from North Carolina and drove back towing a vehicle. Got all the way home turn the truck off went out to restart the truck did not hear the fuel pump Prime, and vehicle would not start. I replaced the fuel pump relay that did not work. I attempted to put 12 volt positive to the fuel pump feed harness and it just sparked back at me so I stopped, and figured the fuel pump is locked up burnt out. It was making the usual loud whining noise for about 2 months ago. The truck has 351000 miles on it I do not know if the pump has ever been changed. I've had the truck since 2009 and have not replaced it. Any suggestions,? Pump?.
. Thanks in Advance
Old Dec 14, 2017 | 4:13 PM
454Guy's Avatar
check the ecm fuse first I just had the same issue with mine its a 20 amp mini fuse in the fuse box under the hood
Old Dec 15, 2017 | 7:39 AM
From your description it sounds like you need to change the fuel pump.
Old Feb 12, 2018 | 8:16 PM
redbear's Avatar
i have heard that the fuel pumps only last to about 125000-150000 if kept cool with at least a quarter tank of fuel to keep it cooled.
if your pump has 315000 then you got your monies worth out of it !!!
JR
Old Mar 10, 2018 | 6:46 PM
Sorry for the late response.. It was the fuel pump, raised the bed and installed a NEW Delphi Fuel pump. Fired rite up..!!!! 353K and running strong again
