Engine power surges in sync with turn signals
Old Aug 17, 2019 | 5:19 AM
  #11
burnhedge's Avatar
I had a similar issue with a 98 k2500 diesel, but the blinkers would actually kill the engine. After weeks of investigating it myself and taking it to two mechanics, nobody had a clue.
I finally broke down and took it to a dealership. The service manager said, Oh yeah that's a ignition switch problem on those trucks. They swapped it out and I never had the issue again.
May just be a diesel thing but might be something to look into.
Old Sep 25, 2022 | 2:29 PM
  #12
Mohawkjacques85's Avatar
Default Resolution?!
Originally Posted by Wes3441
1999 c 2500 engine 5.7L vortec . When I accelerate without the turn signal on it runs great. When I have turn signal on the engine looses power when blinker lights up and clears up looses power and clears up. I have a new fuel pump , battery , alternator. I’m stumped on what could be the issue? Any help would be appreciated
Was there a resolution to this issue? I am experiencing this same thing. I have replaced: ignition switch, blower motor resistor, ac control module, multi- switch, head light switch, battery. None of which have stopped or resolved the issue. I have checked and have not found burnt, cut or loose wires. I am at a loss now.
Old Sep 25, 2022 | 3:52 PM
  #13
hanky's Avatar
If you can do this,
Measure the voltage at both the ign system and "AT" the fuel pump when the problem shows up.
That is the first half of the test. The other half is to verify clean complete ground connections for both. Remember , looking at them does NOTHING. They need to be removed , cleaned and reinstalled and if available a good dielectric grease applied to insure the air doesn't get at them.
As suggested in an earlier post, checking the ground connections from battery to all sheet metal should also be done. That may be how the fuel pump gets it's ground.
Old Sep 26, 2022 | 11:57 AM
  #14
Originally Posted by hanky
If you can do this,
Thanks. I will have to try testing them this weekend.
99Z71
Sep 25, 2009 9:15 PM
Manor_Mullet
Apr 28, 2008 2:13 PM
DERROLD
Aug 17, 2007 3:50 AM
derrik38
Jun 4, 2007 10:02 PM
Alvisk
Mar 29, 2007 3:50 PM
