front actuator
In the past 1 1/2 years I have replaced the front actuator three times. Always the problem the rubber keeps ripping off. Whatvcouldcause this problem and is there a way to fix it Thanks
Get a posi lock cable . It replaces the actuator with a cable that you manually engage in the cab. It's much more reliable and you can get the 4x4 engaged much faster than the older actuators.
