fuel gauge
Old Aug 9, 2017 | 12:28 AM
lewis1952's Avatar
Default fuel gauge
I have a 1994 Chevy Cheyenne 5.0 L. Fuel gauge doesn't work. Replaced the sending unit and fuel pump. Took the cluster out of a friends 1994 GMC and put it in mine. Acted just like mine,all 6 of the other gauges worked but not the fuel pump. My guess is in the wiring a short or a bad ground but where do I begin. I hate wiring.
Old Aug 9, 2017 | 5:10 PM
lewis1952's Avatar
wow so theres 113 other people that don't know anymore about wiring than I do. I don't feel so bad now
Old Aug 9, 2017 | 5:17 PM
kevinkpk's Avatar
Neither would I. Did you plug the electrical into the new sending unit before installing it? I'd try that first. If it's a wiring issue, can you recall what might have caused that?
Old Aug 9, 2017 | 11:46 PM
lewis1952's Avatar
no idea Kevin Just noticed one that it hadn't moved in a couple days starting watching it and it wasn't moving. my friends fuel gauge works in his truck not in mine. I can't find air core motors before 1995 so I guess I'll just start messing with the wiring
Old Aug 14, 2017 | 2:59 PM
lewis1952's Avatar
Default fuel gauge solved
I solved the problem of my fuel gauge staying on full and not moving even when unplugged. I replaced the fuel pump/sending unit with the wrong one. The original had a resisiance range of 0-90 The replacement range was twice that. So just a tip: order sending units and pumps by vin number not by year of the vehicle.
