G80 RPO Codes
Old Jan 13, 2025 | 5:42 PM
  #11
Gumby22's Avatar
What are you considering “a little fast” for the engine speed?
If it’s an automatic transmission, then it’s not going to shift into drive/overdrive very often due to the additional load when towing, so I’d expect 2,000 - 2,500 RPM to be normal, even at cruising speed on the highway.
Originally Posted by FifthWheelPuller
Thanks for the response. The Heritage people did come thru. They found other documents associated with my particular build, and sent them to me by email. Digging into them turned up the codes G80 and GT5. This means that it is the Eaton Locker (GovLock) with the 4.10 ratio.
I thought the engine was running a little fast. Now I know why. The only solution is to find a G80 with the other ratios; maybe one with the 3.21 ratio, since there appears to be no aftermarket replacements available, nor originals either.
Old Jan 13, 2025 | 7:44 PM
  #12
FifthWheelPuller's Avatar
Yeah, you're probably right. Cruising at 1800 rpm is probably not possible.
kevlar55
Feb 2, 2022 4:45 PM
N Dyak
Chevelle & El Camino
Aug 3, 2017 6:17 AM
Gwampa
Sep 30, 2012 12:18 AM
71inliner
Apr 3, 2009 10:38 AM
