Help with the ground wire
Old May 28, 2022 | 9:39 AM
William T's Avatar
Default Help with the ground wire
Which wire on a diagnostic port is the ground wire on 95 Silverado k 2500
Old May 30, 2022 | 12:08 PM
Birdman01's Avatar
If you are talking about the DLC connector port to read the trouble codes, that wire would be the A on the port. You may already know this but to check for codes, you put a jumper wire between pins A&B on the connector/port.
Dee74
12
Jul 13, 2022 12:36 AM
kurt blankenship
May 22, 2017 2:14 AM
pappacherry49441
Jan 5, 2014 10:21 AM
hometheaterman
Jan 15, 2011 6:37 PM
pete90
Oct 4, 2007 6:12 PM
