left front brake lockup 1988 4WD
Old Mar 13, 2016 | 10:13 AM
HomerC's Avatar
Default left front brake lockup 1988 4WD
Left front brake locks up when attempting to drive forward. Releases when in reverse. Disc brakes. Need help!
Old Mar 13, 2016 | 5:01 PM
Smilie's Avatar
Either the caliper is sticking or the brake hose is coming apart on the inside.
Old Mar 13, 2016 | 7:04 PM
HomerC's Avatar
Thanks, I didn't know where to start.
Old Mar 13, 2016 | 9:12 PM
meternerd's Avatar
Clean pads are a must. Calipers have no retract springs like a drum, so sticking is more likely. Lockup on ice happens even when calipers are clean.
Old Mar 22, 2016 | 7:43 PM
wired1141's Avatar
Default been there
Replaced caliper on mine with no results and after talking to service department found the inside of the rubber brake line from the caliper to metal line goes bad over time and won't let the fluid return to the master cylinder so makes the caliper remain extended. I replaced all the brake hoses on mine since this seems like a common problem, hope this info helps you.
Old Apr 3, 2016 | 5:00 PM
HomerC's Avatar
Thanks everyone for your help. Have determined brakes are not the trouble. Left front axle seem to be locking in front differential. Will roll to the rear a few feet and lock then it will roll fwd abour the same distance and lock. Any help?
Old Apr 3, 2016 | 6:01 PM
might want to pull the front diff cover and inspect. have you been running with mismatched tires?
