Loading up at idle.
Old Apr 17, 2017 | 4:39 PM
Pgoines's Avatar
Default Loading up at idle.
New here,
hello to all and thanks for letting me dog around before I joined.
I am stumped...crate 5.7 From gm. I replaced everything that touches or sends fluids into the engine. I am loading up at idle. Checked fuel psi and it wouldn't hold after shut off. No bleed down from injectors or psi reg. So I replaced my 3 week old Delphi pump. Figured it was the check valve. Worked for around 80 miles of that and came back today. 22nd set of modo conversion injectors, 222nd fuel pump, New tps, knock sensor, pcm and elbow, air idle control, distributor, a.c. Delco cap rotor wires and plugs, temp sensor and sender, egr, upper and lower plennum, crank sensor, radiator and hoses, water pump, flex plate and high torque starter. Fuel filter and pcm. What have I missed. I'm back to not holding fuel psi after shut down
