MAF Sensor
Old May 23, 2017 | 8:21 PM
Kaipo's Avatar
Default MAF Sensor
I have a 1996 chevy 2500 5.7 vortec... first I have a code P0102 low voltage to MAF sensor 3wire connector I checked pwr going to connector and have no pwr.. is there a reley or fuse to check.
Old May 23, 2017 | 8:27 PM
kevinkpk's Avatar
Low voltage? 102 with that year should be performance. How are you checking voltage? Black wire is +, yellow is return, red is ground ( I believe). Key on with a (I use paper clip) in the connector
Old May 23, 2017 | 8:34 PM
Kaipo's Avatar
using my test light.. trying to find constant power and nothing
Old May 23, 2017 | 8:52 PM
kevinkpk's Avatar
Two things, check you test light for ground, and the probe into the connector
