New tail light pins loose
Hello all. I purchased 2 new tail light connector plates for a 92 Silverado. The problem I'm having is the pins on the new connector plates are not exactactly the same as the original tail light, so it is making a bad connection causing all sorts of problems. If I try to bend the pins a little to provide some tension they will break inside the plastic of new plate and not work at all, intermittent,etc. I purchased 2 new plates
from Amazon and 1 from oriellys with similar problems. Does any one have a remedy or recommdation for better plates that are exact fit. Thanks, Kai.
