No crank
Need help with finding the starter relay on my 1995 C1500 5.7 L. It's not in the fuse box under the hood and there are no relays or fuses under the dash. Any help would be great. I've been looking on Google and everyone says it's in the fuse box.
Thanks for that, but I've checked all the fuses and they are good. It's just clicking but the battery and starter have been tested. Could it maybe be the ignition starter switch?
Redneck trick - get a helper to hold the key in start position while you lighly tap starter with a hammer - if it starts time for a new starter, even if it tested "good". Any idea how old your starter is?
It's a brand new starter, had it tested before I left the store as this is the second new starter I've been through. I've knocked the starter, but still just a click, but thanks the info.
