No head lights, no brake lights
Hello, Here is what I have...
97 Chevy Silverado 1500 Ext Cab 2WD
These 2 issues occurred a different times.
BRAKE LIGHTS: Running and hazard lights and work. The brake lights went out last summer and I replaced the sensor switch located above the steering column which fixed the problem. They went out out again recently and the bulbs and fuse are good. Having difficulty believing it could be the switch again. I hope it isn't, it was a pain in the *** replacing. :-)
FRONT HEADLIGHTS: A few weeks ago they just stop coming on. No lights work on either standard or high beam. Bulbs are intact and no fuses are blown.
Is there a relay that can be replaced? Any assistance would be greatly appreciated. Thanks.
