o2 sensor help please
Old Oct 3, 2016 | 5:16 PM
Michael Hewitt's Avatar
Default o2 sensor help please
1996 chevy 1500, so bank 1 sensor 2 and 3 are flat lined at 1070-1080 mV, i unplugged them just to see what happens and they go down to the 430mV range, both new sensors, Im assuming bad ground or the likes where should i start/what color wires am i looking for? thanks, both banks sensor 1's seem to be switching normally, ie ranging from 0-700 mV's ish and fluctuating rapidly.
Mike
Old Oct 3, 2016 | 10:48 PM
does the truck has 4 02 sensors
pre cat b1s1 and b2s1
post cat b1s2 and b2s2
the pre cat sensors should switch rapidly in closed loop operation, the post cat sensors should not; if the convertors are working properly.
if you unplug a sensor the 450mv you get is a bias voltage from the pcm...this is normal.
i am confused by a sensor 3 that you are reporting? the pre cat sensors are pinned rich?
what type of injection system is used: throttle body or port injection?
Old Oct 4, 2016 | 6:49 AM
the configuration is b1s1 b1s2 b2s1 precat and b1s3 post cat, the headers collect before the cat. the 2 downtstream sensors one pre and one post cat are the ones pinned at 1080mV the b1s1 and b2s1 precat are both seemingly normal to me switching rapidly varying from 0-6 or 700 mV. the injectors are a MPFI conversion that i purchased from ACdelco. all fuel trim does not vary much from 0% except for the b1s2and3 short ter trim is pinned at 99.2%
and thank you for the help!
Old Oct 4, 2016 | 8:16 AM
don't know what to tell you...I just viewed wiring diagrams for a 5.0L and 5.7L. both show 2 precat and 2 post cat 02 sensors. I viewed a picture of the oem y pipe and it is as you have described.
makes no sense to have 2 precat sensors in the same bank. If it was, it would be switching like the upstream sensor. the data you have provided indicates its switching like a downstream sensor.
does your scan tool read 100%ft as ideal? the adaptive adjustment limit for fuel trim is 30%....no way it can reach a 99% adjustment correction. At 30% it would be setting a dtc. Are you getting lean or rich dtc?
Old Oct 5, 2016 | 7:51 PM
so the higher mV on the sensors is when they are plugged in and the lower is when they are disconnected.
there are 2 downstream sensors one is before CAT and other is after.
