Only starts with starting fluid. Sputter Accel.
Old Apr 1, 2018 | 12:21 AM
Codeyw08's Avatar
Default Only starts with starting fluid. Sputter Accel.
1998 Chevy Silverado Z71 4x4 5.7 Vortec 255,xxx miles
Truck will crank but won't start. It will start only if i spray some starter fluid. Once started it idles fine, but under a load or accelerating it spit and sputters. If i put the truck in neutral and press the gas pedal its fine.
A new fuel tank, fuel pump, fuel lines from filter back, fuel filter, ignition coil has all been installed in the last 2 months.
Cap and rotor, plugs and wires, egr valve about a year and a half.
Hooked a scan tool up to it and it gave me-
p0440 Evap emmisions systems fault
p0446 Evap Vent Control problem
p1404 EGR 2 position error/EGR closed performance
ANY ADVICE IS HELPFUL
Old Apr 1, 2018 | 7:35 AM
kevinkpk's Avatar
Everything I read points to the fuel pump. I realize it is less than 2 months old. Was the issue you are having the same before the new stuff?
Old Apr 1, 2018 | 7:51 AM
Codeyw08's Avatar
No, i only replaced all that stuff because the tank was rusted on top, the lines were rusted near the tank and the pump broke as i was taking a line off. The pump thats in now is still under warranty, so ill replace the pump sometime this week.
Old Apr 1, 2018 | 7:53 AM
Don't buy cheap aftermarket fuel pumps. They usually don't last and with the work involved to change them, they are not worth it. I would only buy Delco or Delphi pumps.
Old Apr 1, 2018 | 9:14 AM
Codeyw08's Avatar
When i turn the key on, i can hear the fuel pump working. Could it still be faulty or bad? Or not have enough pressure during a load to push the fuel or keep it primed? Because once its running it stays on but sputters under a load.
Old Apr 1, 2018 | 10:24 AM
burnhedge's Avatar
In my opinion, fuel pressure testing should be your next move.
Did it ever run right after the work to the fuel system? I bought a 98 awhile back that the previous owner couldn't get to run. Simply purging the air out through the pressure testing port fixed it.
Old Apr 1, 2018 | 11:00 AM
Codeyw08's Avatar
Yeah it ran great the past 2 months. Started, idled, and ran great. Just yesterday i was leaving the store and it took a few cranks to get started and i thought that was odd. As i started driving i accelerated pretty hard and it started sputtering bad. If i got into it a little it ran fine. Made it to Oriellys Auto Parts and shut the truck off. Never could get it to start again on its own. Thats when i used starting fluid to get it going.
Old Apr 3, 2018 | 10:45 AM
Codeyw08's Avatar
Update****
I check my fuel pressure at the rail and had 52 psi key on, engine off. Pressure dropped down to 45 when cranking. Bought a new fuel pump and it now starts right up, no hesitation or cutting out when i accelerate. Thanks guys.
Old Apr 3, 2018 | 9:13 PM
kevinkpk's Avatar
Thanks for the update. That helps with others reading these bulletin boards with like problems.
Old Feb 16, 2020 | 2:37 PM
John Fallis's Avatar
You need a new fuel pump. Get a Delphi pump. Not a cheap one.
