Questions about dry sump plumbing for twin turbo small block
Old Oct 29, 2016 | 12:08 AM
Brian Powell's Avatar
Default Questions about dry sump plumbing for twin turbo small block
Hi all, this is my first post on here and I'm currently I'm working on finding parts for a twin turbo small block build that I'm going to swap into my truck. I'm going to be running a dry sump system and was wondering how I would feed the oil needs for the turbos with the same pump that I'm going to feed the engine with? I know, relatively simple question but I really don't know. Would I need to split the line from the pressure port on the pump with a Y-fitting? Or can I convert one or two of the scavenge stages to pressure stages just for the turbos? Thanks in advance.
