smells like fuel
Old Nov 11, 2020 | 1:33 AM
bode's Avatar
Default smells like fuel
1988 chevy c1500 5.7, this is probably a really stupid question but when i open the doors when the truck is running (usually when idle, like dropping people off) it totally smells like fuel (only when the door is opened, not in the cab alone). Is this normal for these trucks (I just got this truck) or could this be some sort of fuel line leak? I have been having idling issues and it take a bit to crank in the mornings, especially now that its cold
Old Nov 11, 2020 | 1:00 PM
Rednucleus's Avatar
Please check your entire fuel system from tank to motor! If you smell obvious gas odor you may have a dangerous situation waiting to happen.
Old Nov 11, 2020 | 1:25 PM
kevinkpk's Avatar
X2. Is your gas mileage different?
Old Nov 11, 2020 | 2:22 PM
PNW NBS Z71's Avatar
X3. You have a fuel leak and may be back at the tank and on top that you cannot see till drop tank. Inspect while running and smell/look for the wet spot(s). If in the rust belt you may have to repair more than where the leak is at.
Old Nov 16, 2020 | 12:33 AM
bode's Avatar
So i took it into the mechanic, he took a look at it and said that he couldn't find a fuel leak. He said that he found evidence of a fuel leak previously but couldnt find one. He did say something about the fuel pump gushing fuel on these types of trucks if the seal wasnt installed properly. I could have sworn i could smell fuel.. now when i think i smell something i second guess myself.
Michaeladamsjr
1988 - 1998 (GMT400)
Nov 30, 2020 8:49 PM
rssmith1976
Apr 1, 2013 11:10 PM
loagiebear
Mar 6, 2013 8:51 PM
FergusonT
Dec 19, 2012 1:51 PM
racer4611
Jun 8, 2011 6:18 PM
