Smog
Old Jul 11, 2022 | 10:56 PM
Jmc70's Avatar
Default Smog
Smog diagram for 88 Cheyenne
Old Jul 13, 2022 | 5:25 AM
Gumby22's Avatar
Do you need the diagram for the vacuum lines or a diagram that shows where the smog pump tubing hooks up?
Old Jul 14, 2022 | 3:14 AM
Jmc70's Avatar
Yes i do. Thank
Old Jul 14, 2022 | 12:03 PM
Gumby22's Avatar
I’m still trying to find a specific diagram for the smog tube routing, but generally, the pump should have an inlet that draws air from a filter (usually a canister that looks like an inline fuel filter), then an outlet that pumps air to a diverter valve, then from the valve to the exhaust stream which is typically at the manifold, but some systems pumped air to the converter as well.
The vacuum diagram is below.
Vacuum diagram
Old Jul 16, 2022 | 8:06 PM
Gumby22's Avatar
I haven’t been able to find what I can confirm is an accurate illustration (or photo) of the smog tubing for your truck, so here’s a basic diagram of how it should be set up. There’s a little room for freedom on how you want to route the tubing, but the order of the system components (pump, control valve, check valve, manifolds) must be maintained or the system won’t work properly.
pdc420
Chevelle & El Camino
Nov 10, 2018 11:46 PM
Brassman
K5 Blazer
Feb 6, 2017 2:38 PM
pwalk57
1988 - 1998 (GMT400)
Sep 14, 2016 10:51 PM
widanovic
Sonic (Aveo)
Apr 7, 2012 4:34 PM
silverado13
Dec 20, 2010 3:39 PM
