speedometer doesn't work
Old Nov 27, 2018 | 4:04 PM
jetboat36's Avatar
Unhappy speedometer doesn't work
so my 1998 chevy k2500 speedometer doesnt work so i test the speed sensor with a voltmeter put it on ac and use a drill with a bit to test the sensor since is just a magnet and the sensor does work the ac volt raise up when i use the drill. so what should i check next?
Old Nov 27, 2018 | 4:26 PM
jetboat36's Avatar
or anybody got the wiring diagram?
Old Nov 28, 2018 | 7:07 AM
Check the wires going to the sensor as far back as you can.
Old Nov 28, 2018 | 2:16 PM
jetboat36's Avatar
ok thanks
