t700r4 TC cable routing?
Old Dec 28, 2017 | 12:41 PM
Philippe Dieltiens's Avatar
Default t700r4 TC cable routing?
I can't get the TV cable right. If I don't connect it to the carb, the wire springs back in nicely when I let it go, if I put the cable in the bracket on the inlet, it's like it gets a bit stuck or something, however the cable does not take sharp bends or anything and the cable is brand new, I replaced it because the old one had the same issue so I figured it was a faulty tv cable. It has the same length and all, so I'm stuck..nothing seems to help, no matter how I route the cable. From the moment I release it by the carb end, and have the cable "stretch out" it springs in perfectly. It appears to be on the long side, but on the other hand it's the same as the one which has always worked fine...anyone?
