tire fitting
Old Jul 17, 2023 | 12:29 PM
Steven Maloney's Avatar
Default tire fitting
I have a 95 Silverado. when I purchased it, the old owner has some 275/60-15 tires on it. the rim is 10" wide. My question is, will 33x12.50 fit on these rims and will they rub or do I need to do anything if these tires will fit?
thanks
Old Jul 17, 2023 | 3:08 PM
Use a calculator. There's one right at the top of the page in the tools menu. Or go to
https://tiresize.com/calculator/
that's a difference in height of 5 inches! They aint gonna work well without serious suspension and drivetrain modifications.
Old Jan 22, 2025 | 11:11 PM
jfmorris's Avatar
Wow! I wonder if those are stock rims - the tire size is certainly not factory. My 1996 has 15x7 inch rims and P235/75R15 tires on it.
As already pointed out, going too large will cause lots of problems, not to mention throw your speedometer and odometer significantly off.
I would double check the width of your wheels, as looking at tire calculators, you can in fact mount a 265/60 to a 7 to 9 inch rim.
Old Feb 23, 2025 | 4:07 PM
tank1949's Avatar
I had to install a 3" body lift to run 33" tall tires.
rickp
Dec 6, 2012 10:33 PM
Phil.Hugi
Aug 29, 2012 12:20 PM
likearock78
Aug 4, 2012 12:53 PM
edmc1
Nov 16, 2009 8:58 AM
