Typical causes of '94 C1500 to have a "Service Engine Soon" Light
Old Oct 29, 2023 | 12:15 AM
pdude's Avatar
Default Typical causes of '94 C1500 to have a "Service Engine Soon" Light
Trying to figure out different typical reasons why the check engine/service engine now light would be on?
Old Oct 29, 2023 | 1:40 PM
dpieroni3's Avatar
To start, get the codes from the system and see where it leads.
Old Oct 29, 2023 | 3:24 PM
There are dozens of reasons. Don't waste your time chasing dead ends. All you need is a paperclip to get the fault.
flash codes: https://repairpal.com/gm-obd-i-code-chart
Old Oct 29, 2023 | 7:53 PM
pdude's Avatar
https://www.youtube.com/watch?v=vgXSXCRyw2w
Thanks. I've been trying to pull codes that way for a couple of days and only giving me the status (12). Finally on this colder morning, it finally popped up a code for the ignition. I thought it was the gas cap or O2 sensor at first. Hopefully after fixing that the light goes away.
Old Oct 30, 2023 | 12:33 PM
Gumby22's Avatar
Code 12 will always be the first code displayed, regardless if any other codes are stored. The codes also repeat 3 times before it blinks out the next code.
As an example - if you have codes 15 & 23 stored, the codes will flash the SES/CEL as follows:
“1” represents a flash
“-“ represents a short pause
”- -“ represents a long pause
1 - 11 - - 1 - 11 - - 1 - 11 (code 12) - - 1 - 11111 - - 1 - 11111 - - 1 - 11111 (code 15) - - 11 - 111 - - 11 - 111 - - 11 - 111 (code 23) - -
Then it will start flashing out code 12 again and the sequence repeats.
Yodasnax
Nov 22, 2015 2:07 AM
chevykid53
Mar 7, 2013 9:27 PM
menacer1974
Apr 2, 2012 1:33 PM
LTCHEVY
Jan 22, 2011 1:39 PM
alex07
Mar 28, 2006 10:59 PM
