What is the difference in steering column
Old Feb 10, 2019 | 9:39 AM
Jswrench's Avatar
Default What is the difference in steering column
I have 1997 Chevy 2500 4x4 the truck was stolen and they missed up the steering column. I have been look to replace it but there are two different models. The one that fits my truck is a N33 model. There is also a NJ6 model. I talked with the dealership and they were no help. My steering column has tilt and no airbag. Any help would be good.
Thanks
Old Feb 19, 2019 | 1:18 PM
sheepsblood's Avatar
Have you tried calling GM (not the dealership, screw them)? If you do be sure to check your glove box and see if a sticker is still readable inside. It has all kinds of codes that they may ask for when you tell them your issue.
I called once about my brake system because I was at the parts store and had no idea what size rotors I needed. They took the codes they asked for then told me very detailed information about the brake system.
I hope that helps some.
Old Feb 20, 2019 | 7:55 AM
Check this link. There is also a 9J6 model which is basically the same.
Search Results
