00 3500 crank no start
Old Feb 15, 2019 | 8:58 PM
Jules3232's Avatar
Default 00 3500 crank no start
00 3500 4x4 with 7.4 crank no start I've replaced distributor, plugs,wires injectors,crankshaft position sensor,ignition control module. Have no spark and not sure where to start looking
Old Feb 18, 2019 | 12:59 AM
oilcanhenry's Avatar
Check out your MAF ( Mass Air Flow sensor). Hard to believe, but it can shut off the ECM for ignition. Make sure you have no corrosion at the connection there too.
Old Feb 18, 2019 | 7:40 AM
Is the check engine light on? If it is, it will help you find the problem after the codes are read.
