02 Silverado Wayward rear lights <help>
Old Aug 8, 2022 | 12:55 AM
b1blazin's Avatar
Default 02 Silverado Wayward rear lights <help>
Okay so I have a problem with my 02 Chevy Silverado 2500 HD.
The problem is when I push on the brake with my turn signals on all my rear lights go crazy like a rave. Sometimes the reverse lights work at other times they have it. The tail lights do light up. The dash lights have both signal arrow indicators on when I push the brake but not always.
Initially my signal lights did not work. I replaced the combination flasher relay and I feel it made it better and I got the signals back. I also tried replacing the combination function switch w/ no results.
At some point my horn stopped working but now it does. I replaced the brake light switch affixed to the brake pedal & when I did everything was normal again!... But that's lasted not even a day after I went for a drive.
I suspect a ground but the grounds do not show Voltage drop. Wires look ok & fuses are solid.
I hooked up my fifth wheel and the trailer lights do not work at all. Is worth noting when I was hooked up to my trailer I put my left blinker on and when I push the brake there was a buzzing noise and I'm not sure where it came from. Horn? But I have voltage from the 7 pin plug.
I do not have a wiring diagram but I have cleaned all grounds that I can find and I have inspected the tail light junction block and it seems to be okay I've ordered another one just to rule it out but I'm truly at a loss and I am pulling my hair out.
It worked fine after the brake switch but now square 1.
If anyone can tell me what I can do it would be greatly appreciated. Thank you
jsp9r
Sep 3, 2020 3:54 PM
chevy paul
Jan 23, 2013 10:00 PM
beckya99
Jul 12, 2011 12:29 PM
robertwycoff
Astro
Jan 25, 2008 8:52 PM
