03 silverado oil pressure reading high after oil change
Old Apr 4, 2023 | 7:03 PM
treyton baker's Avatar
Default 03 silverado oil pressure reading high after oil change
so recently my 03 silverado z71 was kicking into limp mode and the only problem it showed was oil change needed, so i changed the oil and it’s running normal again but the oil pressure now sits just below 60 at idle and almost 80 when accelerating, i’m not sure what the problem could be
Old Apr 5, 2023 | 4:02 PM
oilcanhenry's Avatar
You didn't use a Fram oil filter did you?
Old Apr 6, 2023 | 11:40 AM
i used an stp extended life filter, could it be because they didn’t have the right blend but we used the same oil just different blend?
Old Apr 6, 2023 | 3:27 PM
STP filters are A-Okay. If you used the same weight of oil for your vehicle it shouldn't have effected your oil pressures.
usernamehere
Aug 2, 2021 12:07 PM
Kylemcclure
Nov 6, 2019 4:35 PM
kenziekay21
Jan 5, 2015 1:38 PM
brokst84
Aug 5, 2014 10:30 AM
northey87
Jan 14, 2008 10:01 AM
