19 and "a" and ..4...4...codes at night?
Last night 7:45 when I locked up the '03 2500hd, I noticed a code on the dash in the dotted blue lights.
It was, 19, with 2 lil blue dots OVER the 9.
The 19 was flanked on BOTH sides by several lower case a's........"a" .....with 1 lil blue dot over each "a".
Down where the blue P, R, D, 2,3 usually show.
THEN, an hour later my SIL asked me to try and take a photo, which my fone would NOT do
BUT
it had a DIFFERENT code
it had two 4's about 3/4" apart with lil blue dots above each like..........4.........4.........
Does anyone know what these codes are telling me? The truck seems fine.....at this time.
many thanx
Trapper J
BUT
many thanx
Trapper J
The 19 was flaned on BOTH sides by several lower case a's........"a" .....with 1 lil blue dot over each "a".
BUT
many thanx
Trapper J
BUT
many thanx
Trapper J
chem_man (January 11th, 2021)
sorry henry
I didn't know there were phony codes and REAL codes
my concern is this runs the battery down when sitting for several days. OR that there is something wrong
it is apparently not the latter, which is good to know
it's gibberish. Doesn't mean anything other than glitchy electronics.
What Mountain Man Joe said below, ronny_jay. We go by OBD II codes, which you can have read at most major car part stores for free, so unless it is something out of the range of the scanner, you can post it here. Makes things much easier.
pretty good chance there won't be any OBD codes. You can try unplugging the cluster and plugging it back in, but it probably needs to be rebuilt or replaced. Or just live with it.
BUT
many thanx
Trapper J
BUT
many thanx
Trapper J
If you’re reasonably skilled with a soldering iron, it’s not difficult to open it up and repair the joints, otherwise you can send it out for repair.
ls0985
February 27th, 2015 7:04 PM
