1999 silverado 2500 sensitive steering
Old Jun 6, 2019 | 7:30 AM
branedge's Avatar
Default 1999 silverado 2500 sensitive steering
just bout 99 chevy silverado 2500, the power steering in way too strong, you can touch the wheel and i basically turns on its on. i know this year had the evo steering but (prior to me) that has been removed. there's no sensor on the steering shaft or plug on the power steering pump. anything i can check. i did replace a restrictor valve(i guess what you call it) that come out of the power steering pump that tightened the steering up some but not enough.
Old Jun 6, 2019 | 8:39 AM
Old Jun 6, 2019 | 9:04 AM
branedge's Avatar
thanks, this was the 1st thing i tried. apparently this has already been removed....the evo sensor is gone and the power steering pump apparently was changed because there is not electrical connectors on it. there's a NAPA tech bulletin about replacing this part http://s7d9.scene7.com/is/content/Ge...58222pdf?$PDF$
